I am creating profiles and I can not get the existing grade linetype to show up as a uniformed dashed line. The layer is set up for a dashed line but the existing profile line is made up of too many nodes to make the linestyle look right. Anyone know how to solve this?
Hello MartinLotofEights,
Make the profile Dynamic and the plinegen functionality will become active. Also, check your linetype setting in the profile style and pay attention to the linetype scale here as well.
Tim
Per the attached you can see the profile is created with numerous nodes which causes the linetype to not be presented correctly. The program will not let you change it from static to dynamic. I know microstation has a command to change this.
plinegen should take care of that regardless of the vertices.
if the profile was a surface profile and switched to static you should be able to set back, but if it never came fro a surface it wont
Joe Bouza
I am using 2013.
So I am creating this profile from an existing groudn surface and when I create it it doesnt give me the option to change it from dyanamic to static (it is greyed out). The existing ground profile is creating with many nodes which looks like it causing this issue.
when I create the profile the attached is what I get. It will not let me change between dynamic and static. I dont know if that is the cause of this or not.
Its odd becaue I can create other profiles in the drawing file and it will let me change between the two.
Martin, your image shows an icon for the profile type to have been created from a file, not a surface. In this image I show a clip from yours and a clip from one of my profile views showing the diferent types, first one is a layout profile, second one is a surface profile, and the last one is a profile from file. The profile from file is always static so you will not get the linetypegen to work with that profile unless you explode it to a polyline.
