Active Contributor
artbiscocho
Message 1 of 8 (798 Views)
Profile-Labeling STATION and ELEVATION at any point along a profile
798 Views, 7 Replies
12-05-2012 12:52 PM
Hi, I posted similar issue earlier, but I am not sure if I explained it correctly. For clarity I drew the attached profile manually. I just want to know the steps in creating label styles as described on the attachment. In my design, I created all the line works in civil 3d 2012.
Regards and thank you!
Go here to create the style
You can add the various components and set their location and rotation.  Have two text components and a line
In the text edior, you can choose what text to have.  Set up one for Station and the other for Elevation.
Go back to the 'General ' tab in your label style composer and change the orientation from "Object' to 'View'
troma
Message 2 of 8 (793 Views)
Re: Profile-Labeling STATION and ELEVATION at any point along a profile
12-05-2012 01:15 PM in reply to: artbiscocho
Credit where credit is due! Give kudos or accept as solution whenever you can.
Active Contributor
artbiscocho
Message 3 of 8 (765 Views)
12-06-2012 08:32 AM in reply to: artbiscocho
A lot of thanks for helping me. It works great, my only problem is I can't orient my labels along with the vertical grid lines. I tried several ways but still my labels oriented perpendicular to the profile line or curve.
Please help again.
Regards and than you!!1
Valued Mentor
KirkNoonan
Message 4 of 8 (760 Views)
12-06-2012 08:58 AM in reply to: artbiscocho
Active Contributor
artbiscocho
Message 5 of 8 (758 Views)
12-06-2012 09:07 AM in reply to: KirkNoonan
Thak you so much. It works great!!! I am so delighted to have this style.
Wish you wonderful holidays, again you the MAN!!!
Jeff_M
Message 6 of 8 (754 Views)
12-06-2012 09:12 AM in reply to: artbiscocho
Art, please be sure to go back and click the "Accept as Solution" button for each of the responses which helped get you through this. It will help future posters find answers to their own questions. Thanks!
troma
Message 7 of 8 (691 Views)
12-10-2012 09:45 AM in reply to: Jeff_M
Jeff don't you have magical powers to do that yourself now?  Or what are expert elites even good for?
Jeff_M
Message 8 of 8 (688 Views)
12-10-2012 09:52 AM in reply to: troma
Yes, troma, I could mark a response as the solution. I would rather suggest to the OP to do so on their own, first, so next time they might do so without one of us needing to ask. As it is, they've now marked the incorrect one so I've corrected it. (They marked my first post as the solution...I changed it to yours and kirk's)
