i've got a profile with a lot of grade labels, some of which i've turned the visibiliy off. i need to turn some, but not al,l of them on. how does one do this?
Don't know if this will work..
Select one, right-click and choose select similar. Hopefully you will see grips for the hidden ones. If you do, deselect the ones you do not want to modify.
John Mayo
it's a new profile. i can grab the grip of the one that is missing but there aren't any options to make it visible.
Once the visibility is turned off it seems there is no way to select it again. I think you are going to have to use the Reset All Label Groups and then hide the ones you don't want again.
Other options I see...
The weeding function in the Profile Labels dialog can limit the number of grade labels.
Use a grade label with the leader turned off and drag the unwanted labels out of the plot view so the can be reset if desired.
Wish they were better solutions.
John Mayo
that's what i figured. it's a shame they can't make it like all the other line labels with labeling a single segment or multiple segments. thanks.
Mark Green
Working on Civil 3D in Canada
