Civil 3D Forum
Profile Glitch 2014 SP1
4 REPLIES 4
hmartinez5
524 Views, 4 Replies
Hello everyone,
I have come across a very annoying glitch that is making me waste too much time.
We have two profile view styles we typically use, one is a 1:1 horizontal and vertical scale and the other has a vertical exageration of 6.
Enter the glitch. When I use the 1:1 everything works as expected, but when I switch the style for the one that has the exageration I can grip edit but the precision is awful and unexpected.
Good Profile (1:1)
Bad Profile (1:6)
The preview shows how the PVI to be moved shifts from the cross hairs and I can't snap to the exact location.
I have toggled OSNAP, purged, audit etc to no avail, even resetting Civil to the default settings. I have used the same styles on different drawings and it only occurs on this DWG.
Any ideas are welcomed.
Tags (4)
4 REPLIES 4
ToddRogers-WPM
in reply to: hmartinez5
Try turning off your tracking.  I noticed that you have the tracking on.
Todd Rogers
K-Mart61
hmartinez5, see this post http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Profile-grip-edit-2014-Service-Pack-1/td-p/45...
The culprit is Axis Offset within the Profile View Style.  Change to 0 and all is well.
hmartinez5
in reply to: K-Mart61
Thank you!
fcernst
I guess so... unless need to uset an Axis Offset.
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Rail Community
