troma
Message 1 of 6 (507 Views)
Profile Geometry Points of Superimposed Profile to Alignment Label
507 Views, 5 Replies
03-01-2013 02:37 PM
I have an alignment label that I normally use to show the PVI's of a profile in the plan view.
This is a little unusual, but in a specific case I wanted to design my profile at one alignment, but show it at another.  I designed my swale profile in the pathway profile view and then superimposed the swale profile on the swale profile view.  I then went back to the swale alignment to add these labels.
It's a no-go AFAICT.  The only profile available for me to select for these labels is the original ground profile from the surface.
Any thoughts?
Credit where credit is due! Give kudos or accept as solution whenever you can.
Joe,
The label style, although you can add a reference to another profile, will only lable the profile geometry points of the profile associated with that alignment. In other words, you can label that other profiles information but, you can't tell it to label at the geometry points of that other profile.
wfberry
Message 2 of 6 (460 Views)
Re: Profile Geometry Points of Superimposed Profile to Alignment Label
03-03-2013 07:21 AM in reply to: troma
I think you are correct with your assessment  I could see a problem with labeling, e.g.,  Sta 1+00 on one profile would probably not be Sta 1+00 on the other, thus leading to complaints of "mis-labeling".
Bill
Joe-Bouza
Message 3 of 6 (454 Views)
03-03-2013 12:04 PM in reply to: troma
You did not mention adding a profile reference component to your lable style. You should be able to do this and then select the desired profile.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
BrianHailey
Message 4 of 6 (449 Views)
03-03-2013 01:38 PM in reply to: Joe-Bouza
Joe,
Brian Hailey
CAD-1.com
My Blog
Joe-Bouza
Message 5 of 6 (440 Views)
03-03-2013 04:52 PM in reply to: BrianHailey
Brian,
I see
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
troma
Message 6 of 6 (412 Views)
03-04-2013 05:25 AM in reply to: BrianHailey
Hey, thanks for coming in on the weekend guys!
What you're saying is making sense.  My labels that come in at regular stations work, and the ones at horizontal PI's work.  Both of these are reference text, as Joe suggested.  The ones designed for Vertical PI's don't work, as Brian said.  I guess I shouldn't be too surprised about that considering that the superimposed profile can't even label PVI's or Grade labels in profile view either.
