I only get 2 choices when selecting corridor feature line to create profile - ETW_base, and ETW_sub. My Subassembly has 2 pavement sections, a base and subbase section. I need the top of pavement profile. What am I missing.
Solved by sboon. Go to Solution.
You should be able to get a profile from any featureline that is currently being displayed in your corridor. Check the featurelines tab in the corridor properties dialog and make sure that ETW is turned on.
Hello
It is important to check your Code Set Style, and if you are using a Subassembly GenericPavementStructure, have to set the codes for each part.
Adriano Oliveira
Diretor Soluções BIM MaxiCAD
MaxiCAD Soluções e Educação BIM.
Facebook | Twitter | LinkedIn
