Member
eduardo.frias
Message 1 of 9 (1,693 Views)
Profile elevation in alignment label
1693 Views, 8 Replies
09-25-2012 01:19 PM
Hi.
I need to know how to display a proposed profile elevation in the major station alignment label, I mean, for example, I want to read in the label "0+000, 494.444". I've already edited my major station label style adding a (profile type) Reference text, and it only displays "???". I suppose I need to associate it with the correct profile, but I've not figured out how to. I show you how the label looks in the attached image.
Does anyone have an idea?
Eduardo Frías
Monterrey, México
Not sure what types of labels you are using so try holding down the CTL key, select one or all of the labels. Go to the properties dialog and close to the top there is a field for the link. There is a little green icon to the left of that field. Double click it and then right click in model space. A dialog should appear. Now this is a bit of an odd procedure and I probably do not have it mapped out perfectly with the clicks here and there so play around and you should be able to get it.
jmayo
Message 2 of 9 (1,687 Views)
Re: Profile elevation in alignment label
09-25-2012 01:32 PM in reply to: eduardo.frias
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
Jeff_M
Message 3 of 9 (1,685 Views)
09-25-2012 01:36 PM in reply to: eduardo.frias
You must select each label using CTRL+Leftclick, then in the properties palette you can set the Profile to use. You don't have to edit one at a time, but you do have to select each one (CTRL+Window also works).
Member
eduardo.frias
Message 4 of 9 (1,664 Views)
09-25-2012 03:48 PM in reply to: jmayo
Excellent!
I finally found the field. It seems so simple now!
Thanks a lot, John!
Joe-Bouza
Message 5 of 9 (1,662 Views)
09-25-2012 03:53 PM in reply to: eduardo.frias
Also, if you save the style containg the profile reference label to a label set, when you load it to label and alignment you will be promted for the profile.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
KINGDAVID2
Message 6 of 9 (1,610 Views)
09-27-2012 03:39 AM in reply to: eduardo.frias
hi, i saw your message on this topic am having the same problem its only givin me ???, pls can you describe how to link the text to the profile
Active Contributor
jamesmac1200
Message 7 of 9 (1,601 Views)
09-27-2012 06:00 PM in reply to: KINGDAVID2
The reference text label style can be retrieved from two locations. One is the properties of the label. If you add the label and it shows the ???, just select the label and look at the properties. There will be a field at the top to select the applicable reference. By default, it should be blank. Just click in the blank area then select the appropriate reference. The second method is as you add the label, right click and a menu will come up to select the appropriate reference.
Civil 3D 2014 SP2
Intel Xeon CPU E5-1620 v2 @ 3.70 GHz
16GB RAM
64-Bit
Window 7 Professional
KINGDAVID2
Message 8 of 9 (1,595 Views)
09-27-2012 11:51 PM in reply to: jamesmac1200
tanks for ur helpful contribution
troma
Message 9 of 9 (1,506 Views)
10-30-2012 08:35 AM in reply to: Joe-Bouza
I can't get it to work when adding the label, only in the contrived manner described by Johnm, after the label appears.  Is this some sort of glitch?  It works so easily with profile geometry points, but really difficult to get it to work as profile elevations at regular stations.
Credit where credit is due! Give kudos or accept as solution whenever you can.
