Please see attached pdf's. In the Band Style_A pdf you can see the location of my elevation labels, they are below the bottom line of my profile view grid. In the Band Style_B pdf the labels are showing up in the proper location (above the bottom line of the profile view grid). To move the labels to the proper location I changed the "Gap" setting from 12.5 to -24. Is there a way to change this setting in my "style" rather than have to go make this change to the style every time I use it in a profile??
Solved by BrianHailey. Go to Solution.
Save the setup of your bands as a Band Set. You are changing the gap between bands so this setting isn't saved with any particular band. Once saved, you can reuse this band configuration anytime you need by importing the band set.
