Civil 3D Forum
Production Tools (Several Alignments)
10 REPLIES 10
Message 1 of 11
BenzyMH
644 Views, 10 Replies
Hello everyone
Ok, I love Civil 3D, it made my life easier, but i have a complicated situation, and i would appreciate help 🙂
I attached a PrintScreen for my situation,
We have a main line (1 Alignment) and some junctions on that main line (other Alignments), and out GOAL is to create GL (General Layout) sheets, showing Shading, Setting out and Dimensions..ETC.
So every VFG (View Frame Group) i can generate cut sheets from it, the Question is
1- How can i "connect" all the VFGs you see in the image attached into one VFG so that i would create them together ?
2- OR should i make separate VFGs like you see i did already , and then create cut sheets for each VFG ?
3- Or am i the only one facing this Problem ? 🙂
Hope to hear from you Pros ! 😉
My System Info
Manufacturer Hewlett-Packard
Model HP Z800 Workstation
Total amount of system memory 24.0 GB RAM
System type 64-bit operating system
Number of processor cores 6
My Graphic Card Info
Display adapter type NVIDIA Quadro 2000
Total available graphics memory 13047 MB
Dedicated graphics memory 1024 MB
Dedicated system memory 0 MB
Shared system memory 12023 MB
Display adapter driver version 9.18.13.2078
Primary monitor resolution 1920x1080
Secondary monitor resolution 1920x1080
DirectX version DirectX 10
10 REPLIES 10
Message 2 of 11
Jay_B
in reply to: BenzyMH
@BenzyMH wrote:
Hello everyone
Welcome to the Forums!
The View Frames are dependencies of each alignment they were created from so it's not possible to combine all alignments shown in your screen capture into one VFG. HTH
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 3 of 11
BenzyMH
in reply to: Jay_B
Thanks Mr. Jay
So i guess i should prupose this option for Autodesk for the newer versions of Civil 3D, and while i was playing i got a way around, (Still Under Progress) which is:
1- I will create VFG for the Main Line,
2- At each Junction, i will move the whole View frame to cover the Junctions Arms (Which i know will still be connected to the Main line Alignment), and i keep doing it manually for each junction in way untill it fits my design (Note that we are generating Plan Only Cut sheets).
I guess i will give it a try and see how it looks like,
Thanks though fr your reply
My System Info
Message 4 of 11
DaveM
Although the frames are alignment dependent, you can create a SSM that controls all of the seperate alignment's sheets. Which will alow you to creat a single PDF of all the sheets in one PDF.
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
ATI FirePro V5700(FireGL)
Win 7 Home Professional
Please use Kudos Where Deserved
Message 5 of 11
BenzyMH
in reply to: DaveM
Thanks dmartin, That's exactly what i was planning to do, but here is the result for my trial
1- I inserted a new VF and moved it to the arms of the Junctions and rotated it and everything was fine, But
2- Here came the Match Line, that only slides on the Alignment but Can't move away like the View Frame can !
So that is a Failure !
any Suggestion ?
I mean Civil 3D is awesome if you just have 1 Alignment and everything will go fine, but what about JUNCTIONS !?
Images attached to show the FAILURE !
My System Info
Message 6 of 11
Joe-Bouza
I guess what you are hoping for is 4 matchlines for a junction overlap?
I would try to make a vfg for the mainline and adjust the vf to cover the junction completely (like you would if you were doing by hand) then I'd make a vfg for each side of the junction, add them all to the same SS and if I had to add a see sheet note I'd add it manually via SSM.
If you cannot move a vf along the alignment go back in the wizard and adjust the settings
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
Message 7 of 11
sboon
If you're creating Plan only view frames then you can turn off all of the match lines.  Unfortunately you'll have to live with overlap in your sheets, but this may be acceptable.
Steve
Expert Elite Alumnus
Message 8 of 11
BenzyMH
in reply to: Joe-Bouza
That is a good option, which i tried, but i will end up (according to the scale required b ythe Client 1:500) that the last cutsheet on one of the arms is half a cutsheet !
its terrible!
But thanks for your input Joseph D. Bouza
My System Info
Message 9 of 11
BenzyMH
in reply to: sboon
I can try this option Sboon !
and see what you mean by the overlap, because i can manually add on each cutsheet on the layout tab, a Wipeout to hide the overlap and repeated parts ! but thats a hell of a work, 40 Cutsheets !
My System Info
Message 10 of 11
sboon
Don't use a wipeout.  Once the view frames are created draw lines across the alignment at the locations where you want to have match lines.  Make sure that the viewport in your plan template is polygonal, not just a simple rectangle.  Once the sheets are created you can go through them and grip edit the viewport corners so that they snap to the endpoints of the fake matchlines that you drew earlier.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Message 11 of 11
BenzyMH
in reply to: sboon
Thanks Steve, that is actually a better idea 🙂
But wouldnt be nice if the awesome Autodesk thought of JUNCTIONS as a possblity in any major road design ? 🙂
Still love Autodesk though
My System Info
Rail Community
