Is this - intel (r) core (tm)2 duo cpu e6850 @ 3.00 ghz 2.99 ghz - processor good enough to run Autocad civil 3d 2014? I looked at the processor requirements but I don't understand them.
You might want to take a look at this site: http://www.cpubenchmark.net/cpu.php?cpu=Intel+Core2+Duo+E6850+%40+3.00GHz
Any processor that will run a 64 bit OS should be able to run Civil 3D. Run it well. Probably not. This one does seem to be withing the minimum requirements. What are the specs of the computer it's going to be in?
Being a dual core isn't much of a disadvantage when running Civil 3D. Civil 3D doesn't do much multi-threading. However if you're going to be gunning a couple of other programs at the same time. You might notice some lag.
Allen
Allen Jessup
CAD Manager - Designer
Clock speed isn't the sole measure of how fast a processor is. While a Core2Duo and a latest generation i5 may both have a listed clock speed of 3 GHz, the features in the newer chip and supporting chips on the motherboard (QPI, SATA 3, USB 3, and so on) will process more data, faster. Operating system can have an effect as well. 32-bit XP flies on the older processor but 64-bit Win 7 is a bit pokey at times, while the modern processor barely notices x64 Win7.
For what its worth, I'm on a Core2Duo Xeon right now and while she's been a trooper its one of the last in the company as IT has been cycling them out wherever possible.
The computer is running 64-bit Windows 7. It is the computer I'm making the deployment for Autocad civil 3d 2014. The computers that run the program from here will hopefully have a more updated processor. But good to know that this processor will work for now.
I'm running a Core 2 Duo 6400 in a Dell workstation that I bought back in 2007. I've maxed out the RAM to 8 GB, and I put in a larger 1 TB WD Black hard drive. Civil 3D runs acceptably on this setup for me, but I'll probably upgrade to a new machine in the next year or two. I'm pretty happy that I've been able to squeeze seven plus years out of this machine with a few upgrades along the way.
