AutoCAD Civil 3D General Discussion
*Expert Elite*
doni49
Message 11 of 19 (270 Views)
Re: Problems with creating a conditional subassembly
03-12-2014 01:34 PM in reply to: doni49
It sounds like you might be better off using a custom SA.  You can set one up that will accept a min and max WIDTH then if you can hit the surface within that range using a specified slope, then do so --otherwise use the alternate slope.
Don Ireland
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Forum links:
AutoCAD 2013/2014/2015
AutoCAD 2010/2011/2012
AutoLISP, VB and other AutoCAD customization
Civil 3D General
Civil 3d Cusomization
Valued Contributor
JBozz300
Message 12 of 19 (265 Views)
03-12-2014 02:22 PM in reply to: doni49
I guess in my case that makes no sense to use a condition subassembly based off of depth at any point as opposed to a horizontal offset. That's where I messed up; I thought that the min-max distance was a horizontal distance that the condition would run from the origin (EOP) then would change to the other condition if not met.
JBozz300 Out!
C3D 2014 SP1
i7-3770 @ 3.40
16 GB - Win 7 Pro-64 SP1
NVidia Quadro 2000
Valued Mentor
fcernst
Message 13 of 19 (253 Views)
03-13-2014 05:45 AM in reply to: JBozz300
You can still use the ConditionalCutFill subassembly to test whether you are in cut or fill at the 25' offset mark, then proceed accordingly:
Fred Ernst, PE
C3D 2015
Ernst Engineering
www.ernstengineering.com
Valued Mentor
david.zavislan
Message 14 of 19 (244 Views)
03-13-2014 07:57 AM in reply to: JBozz300
Use generic link subassemblies to shift the conditional test location 25 feet.   Test to see ff the depth is greater than 1.25 (25' x 5%).  Then on the end of each condition, use generic links to return back 25'.
Read more here:  http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Comparison-point-on-conditional-subassemblies...
David Zavislan, P.E. | Wood Rodgers, Inc.
Valued Mentor
fcernst
Message 15 of 19 (226 Views)
03-14-2014 03:27 PM in reply to: JBozz300
One scenario that simply testing for cut or fill at 25' @ 5% like I suggested with a ConditionalCutFill SA would fail at,  would be if you had a hump in between that you did not want to grade out through, and you were in fill at the 25' offset test point.
Fred Ernst, PE
C3D 2015
Ernst Engineering
*Expert Elite*
sboon
Message 16 of 19 (217 Views)
03-14-2014 08:08 PM in reply to: JBozz300
Reading the original post I want to be sure that I understand the intent.  Starting from the shoulder the section extends outward at -5% until it daylights or reaches 25' from EOP.  If it reaches the 25' without daylighting, then it continues at -3% until it daylights, or falls of the edge of the surface.
This is DaylightGeneral.  With the Fill1 link is set to -20:1 for 25' and the Flat fill slope set to -33.333/1 it should perform as shown below.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Valued Mentor
fcernst
Message 17 of 19 (195 Views)
03-15-2014 07:31 AM in reply to: sboon
I can confirm.
I didn't realize DaylightGeneral had this initial Fill Width funtionality for this problem (Kudos given). This will solve that hump scenario where the cut/fill test at 25' would fail.
Fred Ernst, PE
C3D 2015
Ernst Engineering
Valued Contributor
JBozz300
Message 18 of 19 (168 Views)
03-20-2014 06:53 AM in reply to: doni49
I did not try this last scenario and will need to give it a try.  I ended up creating a new baseline along the EOP and running out the -5% to determine where it went past the 25' offset.  In the areas that went past it I just created a different assembly that went to the 25', then matched from there at the -3%.  For the most part, the areas that went past were confined to 2 long areas and so it was pretty easy to designate the regions.  This also allows me to basically let the pavement on the runway to be independent so-to-speak from the infield area as they usually need some additional contour tweeking.  Thanks for all of the help guys......
JBozz300 Out!
C3D 2014 SP1
i7-3770 @ 3.40
NVidia Quadro 2000
Valued Mentor
fcernst
Message 19 of 19 (159 Views)
03-20-2014 08:53 AM in reply to: doni49
Boon's suggestion automates all of this and is easy to set up.
I never use DaylightGeneral because it doesn't have capability to target horizontal and elevation targets which we always need to tie ditches into culverts and bridges.
However it works perfectly for your Fill problem, and I will consider using it for more Fill scenarios now.
Fred Ernst, PE
C3D 2015
Ernst Engineering
Announcements
Need installation help?
