Civil 3D Forum
problems when creating blocks with attributes
6 REPLIES 6
wbrustle
342 Views, 6 Replies
Our company has created some blocks with attributes and when using the move command with these blocks when it asks you to pick the second point of placement, I can no longer visually see the block, but when I save and then exit the drawing and get back in, the block is there....anyone else have this issue when using the move command?
6 REPLIES 6
Jay_B
in reply to: wbrustle
Try turning on Hardware Acceleration and see if that helps.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Did you try typing regen
wbrustle
How do you turn on hardware acceleration? Yes I have tried regen and it makes it worse. Actually, after the regen command all my graphics disappear and I can no longer see anything on my screen anymore...but as soon as I save, exit my drawing and get back in, everything is normal again.
Jay_B
Lower rt. of screen there should be an icon that looks like a speedometer needle.
C3D 2018.1
C3D 2016 SP4
wbrustle
I just tested something else in the drawing, it seems to happen when I move the block only the first time. Once I save, exit and re-enter drawing, that block that is now on my screen again seems to move all over the place with out a problem.
wbrustle
thank you Jay......that seemed to work!! What exactly does turning the hardware acceleration on and off do? Should I always leave it on?
Rail Community
