Civil 3D Forum
Problems subassembly when I have restart my windows.
1 REPLY 1
153 Views, 1 Reply
I have made subassebmyly made in subassebmy composer.
now I have restarted windows and when I open civil 3d files it doesn't see my subbasambly. and says that one more micro subassambly is missing. now I have add in tool pallete my subassambly and it still can't see and I can't rebuil my corridor. can someone help me with this problem.
1 REPLY 1
Dexterel
You probably change the name of the subassembly in SAC. Or you made another subassembly with the same name and got overwritten. Always change the name of your subassembly's and don't keep the default name "Subassembly1".
Try adding the subassembly from tool palettes and replacing:
When prompted to insert subassembly select Replace, after that select the subassembly that doesn't work.
Select marker point within assembly or [Insert/Replace/Detached]: R
Rail Community
