As we all know that irc for rural roads with frequent intersection says that super elevation can be restricted to 4% but when ever we generate superelevation for plan and roalling terian , by default it taks or ristricts for 7% so it becomes very difficult to manually edit especially when there are more no of curves in a alignmant
also the softeare doesnot as consider the methof of attainment of superelevation ie pavement is rotated abovt its center or from inner edge or from outer edge
pls suggest a solution for this problem
Version number?
I am able (in 2012/13/14) to select a pivot point position other than centreline.
Solution, Upgrade possibly.
Version is 2013,
you mean to say we have to do it manually by dragging the pivot points..?
if that is so it dosnt save my time na..?
in the superelevation wizzard, pivot points. Or did you mean something different?
The superelevation rate is controlled by the selected design criteria file and superelevation rate table. If the default files do not contain the values that you need, you can create and edit your own criteria files.
Wat you suggested is by following AASHTO code but i want to follow the IRC code in which rate of attainment of superelevation is different , also the design from AASHTO varies with IRC design so i need 4% superelevation to be done using IRC code .
I did not suggest that you use ASHTO standards. My intent was to show where Civil 3D gets superelevation rates from design criteria files. I am in the United States, so the version of the software that I installed comes with AASHTO design criteria files. The country kit that was selected when you installed Civil 3D may contain IRC standards. If not, you will need to create your own design criteria file.
