Civil 3D Forum
Problems Exporting from Civil 3d 2014 to LT 2014
2 REPLIES 2
dimensionsdrafting
235 Views, 2 Replies
My client is using AutoCad LT 2014 While I am using Civil 3d 2014 (soon to be 2015) Currently I use - Export - DWG - 2013 or 2010 He can open them just fine but any text that is Annotative he has to scale, rotate etc to get it to look right. Such as Contour Line numbers, Point Numbers/text and profile/section text height. One of the biggest problems has been the profiles and Sections all have multiple numbers and varying heights. Is there possibly a better way to export to LT? Thanks for any insight!
2 REPLIES 2
odoshi
in reply to: dimensionsdrafting
If he needs it in different scales, you would have to be the one to export it for him.
So, export a DWG at 100 scale, and if he needs a 50 scale, flip the annotation scale to 50 and export to DWG again.
It will be a lot easier for you than for him.
Mike
Mike Caruso
Autodesk Certified Instructor 2014
AutoCAD/Civil 3D Autodesk Certified Professional 2014, 2015, 2018
www.whitemountaincad.com
dimensionsdrafting
in reply to: odoshi
How about installing the Object Enabler for LT? Will that take care of annotation text? I've also tried simply turning Annotation scale of at the style level. However that seamed to make no difference. At least not on the profiles and sections. I am getting multiple numbers on the sections and profiles in Model Space. They look great in the Viewport but have 5 or 6 different Numbers all at different scales for the Stationing along the bottom and Elevations along the sides.
Rail Community
