hi everyone..ı need to desıgn a project but ı cant..ı have two profiles in use for one alignment..ı want to use left profile for left side, use right profile for right side.and ı want to draw crossection only one..how can ı design like this project..
ı attached my plan..
This is the third post I've seen from you asking for help on the same issue -- all within less than an hour of each other. Everyone here volunteers their time. The fact that you don't get an answer right away doesn't mean that you WILL NOT get a reply.
Also I'd suggest making the subject line a little more descriptive of the issue. A lot of people will pass right on by such a generically titled message.
Don Ireland
Engineering Design Technician
Although you can do this by using a hidden link for each side to target an offset alignment with profile as required from the "master" then deign the subassembly on that.
I recomend not doing that in this case!
The centreline geometry & length is different from each designed lane. I sugest you design each side of the road from the actual centreline on the road not a sudo centreline. especially if you are requiring superelevation.
Please concisely define problem!!
A corridor model can contain multiple baselines. You can also use a trick with hidden genertic links to offset a subassembly from one baseline to annother or use an offset assembly.
ı attache a jpg file...ı need to design like this..
some kilometres left profile high level right profile low level..some kilometres right profile high level left profile low level.
thanks Mr.Evans for your helps..
I assume that pivot is Left./Right lane superelevation pivot points.
Design two aditional alignments for each pivot with profiles. Set superelevation for each alignment and create seporate subassemblies for left and right lanes with a Generic link from left or right to median centreline.
Create corridor with each pivot baseline following superelevation rules, target median profile and alignment with generic links.
To create the median profile.. Add two generic links on each side (offset and slope) set slope for max/min value (one for each) create surface of min/max planes. superimpose profile on median alignment and design suitable profile to deviate between the two profiles. Delete one following design. Set profile targets to the new profile.
I will..
To get the answer quicker next time.
Provide a more detailed description & information on the problem.
Include pictures, hand drawn if nessesary.
Include the sorftware version and service pack where applicable.
