I'm working with Ciivil 3D 2010. I've open a drawing with an existing surface that represent final ground elevation. When I check points or points groups, nothing is listed??? It's seem that points list had dissappeared. In an other drawings, I have a similar problem : I see points of existing grounds, but I cannot see points list or use the points of what I am seeing on the screen to create a surface... Does anyone already have a similar problems??
Thanks in advance!
Sincerely!
In one case, I see that points effectively were off into surface style. Does the point list generated from the surface can be display somewhere? Thanks Steve!
In other case, I have a drawing without surface and points list, but I see all the objects on the screen. I've posted a picture in my previous post.
Check the definition of the surface to see if it was actually created from points.
Allen
Allen Jessup
Engineering Specialist / CAD Manager
