Attached is a picture of the problem. This is a picture in a drawing in which the pipe network is DREF'd. It also does this in the parent drawing. The magenta line at the bottom of the profile view (it extends to the left for several hundred units), when clicked, comes up as part of the structure. The style shown uses a block (basically a vertical line of arbitrary length) to get a single line for the structure. It also does this when the style is set to display as boundary (but the line is a different length). The parts used for the structures are SI with a 0 mm floor thickness setting (one is a rectangular structure, circular frame; the others are 1200 mm cylindrical no-frame).
Has anyone had this problem? Any solutions? Please advise as this is killing an incredible amount of time.
Mike Kitchen
Civil 3D 2014 sp 1
Solved by MikeKitchen5860. Go to Solution.
Additional...
I have uninstalled and reinstalled C3D. I built a completely new test drawing using the default metric profile. Built a surface from points, draw a pipe network, created an alignment from it, cut a profile and created a profile view. The lines are still there. I exploded one of the structures, the lines are on the C-STM-PIPE layer. I have looked at every setting I can find.
The only thing I did was use the part builder to allow the floor thickness (Fth) to be set to 0 mm. This was previous to uninstalling and reinstalling.
Often times I'll see issues when setting values to 0. Go back into your part builder and change the floor thickness to something very small (0.0001 for example). Perhaps that will fix it?
Thanks for the follow up Mike. You should mark that last post of your as a solution so others searching the discussion groups can see there is a solution in the thread.
