I could work with slope patterns on corridors.
If you don't mind can you give me the corridor dwg that isn't working for
you, so that i can a take a look and help you out?
Chakri
chakravarthy.gavini@autodesk.com
"snowdrop" wrote in message
news:31136252.1100775359477.JavaMail.jive@jiveforum1.autodesk.com...
> Slope patterns in Civil3d2005 simply don't work at all !. I have created a
corridor and then i go to slope patterns tab, select feature, i select as
feature line 1 the end of shoulder (EPS) and as feature line 2 the daylight
fill. The program just crashes, or corridor lines disappear, or it produces
some lines which are completely messed up. I tried same thing for a smaller
range of station and in some cases it does it correctly but not for the
whole alignment. I also tried exporting corridor feature lines to grading
feature lines and create a grading from these lines to the existing ground
surface. It don't work either. Is it a bug ? Is there a way to get it
working right ?
