Civil 3D Forum
problem with scale when importing a block
6 REPLIES 6
achillesgr
385 Views, 6 Replies
Hello, I have a DWG that I set meters in the drawings settings units tab .I use the block to make a block an area of that drawing. When I import this block in another drawing i t comes scaled smaller and the block import popup shows fleets as units. Why the block from a "meter" drawing exported as "feet"? Please help. I changed every setting I saw under the drawings settings dialogue to meters and I still import the block as feet. Thanks!
6 REPLIES 6
IanMcClain
in reply to: achillesgr
Verify that the source and target drawings are set to meters under the UNITS command.
Verify that the INSUNITS is set to 0 (or 4 for metric/millimeters, as long as both drawings are set to meter under UNITS).
Lastly, verify that OPTIONS>User Prefernces>Insertion Scale is set to Unspecified - Unitiless for both source and target (all that matters is that they are the same).
Ian McClain
mathewkol
Also, edit the block and make sure its units are metres.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Pointdump
in reply to: mathewkol
Matt,
Where in the Block Editor would you reset a block's units?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
mathewkol
You'll find "Units" in the Properties palette once you've entered the block editor.
Matt Kolberg
Pointdump
Thanks, Matt. I didn't think about opening the Properties Palette inside the Block Editor.
Dave
Dave Stoll
Las Vegas, Nevada
<a href="http://maytinhtiendientu.com">máy tính tiền điện tử</a>
[url=http://maytinhtiendientu.com]máy tính tiền điện tử[/url]
Rail Community
