Hey everyone,
I'm having issues with my toolbox--> Subscription Extension Manager--> Utilities--->Import styles and settings for Civil 3d 2011.
I'm getting:
Command: _AeccUiImportStylesAndSettings
Unknown command "AECCUIIMPORTSTYLESANDSETTINGS". Press F1 for help.
It's really annoying. I'm back to using the regular command line.
Is there anyway of fixing this? All the other commands work except this one and it works on my co-worker's machine. I tried switching workspaces, rebooting etc etc. Nothing seems to solve it.
Thanks.
Solved by Plaz44. Go to Solution.
You must have the AeccUiSAP.arx and AeccUiSapEnu.dll files in the C:\Program Files\AutoCAD Civil 3D 2011 folder. If you have these files and it still does not work then use the appload command and load the arx file. This should alllow the import styles command to work then.
Thanks Plaz44
i appload the arx even though Autocad said the arx was already loaded.
I got my browser back and now finding files is a cinch
