I am unable to either modify or delete the corridor named "Road" in the attached file. When I try to modify or delete that particular corridor, the program freezes and in task manager the program is “Not Responding”. Is anyone able to update or delete that corridor or tell me why I am unable to? Any help would be appreciated. If you are able to modify/delete the corridor, could you please email me the file at ohbilly80@hotmail.com. Thank you!
I tried several methods with this drawing and to no avail, it won't let you do anything with that corridor.
Take a look at your corridor in a 3D view. You will see that the end section at station 0+99,85 dives straight to a zero elevation because your profile only goes to 0+99.80. Shorten youe corridor to this station and everything seems OK.
Thanks for you suggestion! When i change the length in the of the corridor and then click "OK" (or even click "Apply" before I click "OK") or when I use the grips to change the length, it freezes. Were you able to successfully shorten the corridor without it freezing? If so, would you mind sending me the file? I would REALLY appeciated it. Thanks again!
