I'm running to a problem with my Civil 3D file when it comes to grading.
I have 2 separate files, one saved at an earlier time and one saved afterwards.
When I grade with the one I saved afterwards, It freezes and crashes on me. I'm wondering if there is someone out there who knows a solution or a work-around for this issue.
Grade the lots #23-#29 using the corridor to turn it into a feature line and then step offset it towards the south...
Thanks ahead of time if anyone has a solution.
unfortunately, the file size is >1.5mb (2.8mb) so wouldn't allow me to attach using the forum options
I haven't grabbed your file yet because Im not near a work station. Question: you mention corridor? Is this a grading issue with grading wizard? I have found most issues with grading go back to the Feature lines; too many verts, bad geometry (i.e. Presence of pseudo nodes, sharp turns, etc.), overlaps with other FL in same site, and using undo during grading operations. ( ever notice the grading panorama is one of the few without an undo arrow?).
Are any of these factors possible in your grading problem?
Joe Bouza
