Civil 3D Forum
Problem with Extracting Dynamic Feature lines from Corridors
8 REPLIES 8
Message 1 of 9
651 Views, 8 Replies
Hi All
When i try to extract a feature line from a corridor using "feature lines from corridor" it is not allowing me to select any feature lines from the corridor. It is a basic assembly with basic conditional cut and Fill parameters on either side. I am following the instructions found  here in an effort to deal with bowtieing on a tight hairpin. Why can i not select the feature Lines?
Kind regards
8 REPLIES 8
Message 2 of 9
jmayo-EE
Without seeing your corridor I wil ask you to try again but before you do so take the corridor and move it to the front of the display using DrawOrder.
John Mayo
Message 3 of 9
in reply to: jmayo-EE
Hi Jmayo
Thank you for your response i have tried doing as you instructed and still no joy. It is my inderstanding  the featurelines are automatically generated along the corridor and i do not have to carry out any further process prior to the feature line from corridor command or am I missing something. Could it be an issue wih my display setttings in the corridor?
kind regards
Message 4 of 9
jmayo-EE
Do the feature lines display in the corridor?
Can you post the file or a small portion of the corridor?
John Mayo
Message 5 of 9
If it were up to me i would, but given my companies policy on sensitive sites i do not want to risk it.
The feature lines display on the corridor, please see attached image. The pink highlights the region without any day light that I wish to grade, just pavement with reduced frequencies. The blue lines are my target feature lines this image is obvioulsy with corridor properties open, usually the feature would display as a narrow blue line. Capture.JPG
Message 6 of 9
Joe-Bouza
Have you tried turning on selection cycling or isolating the corridor?
Joe Bouza
Message 7 of 9
Harold_Alberto
Hi Paul,
Have you checked if the corridor featurelines are set to be shown.  The featureline you wanted might be set to '_No Display'?
Or maybe the layer is turned off?
Harold
Message 8 of 9
in reply to: Harold_Alberto
Hi All
Thanks for your responses guys it was indeed a display setting.I changed the code set to a more transparent style and am now able to select them.
Kind Regards
Message 9 of 9
michaelrupp61
I sometimes have to 'pick' a feature line several times and then return to get the dialog box to open showing the feature line options
Rail Community
