Civil 3D Forum
Problem with Creating Alignment
3 REPLIES 3
343 Views, 3 Replies
 I have a problem when i create an alignment with Select Object. The Chainage is not coming properly.
And here i attached the Print screen, please see that.
3 REPLIES 3
The screen shot looks good.  If there are gaps left in the alignment, check to be sure the poly line is one entity.  I have had it leave gaps before when i had a section that was at a different elevation.  I don't do much work with the alignments, but since it's Saturday and you are working, I thought I would give it a go.
Surveyor Lee
What, exactly, is the problem? It looks fine to me, without seeing the alignment properties.
neilyj666
nothing obviously wrong with this; any more clues?
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Rail Community
