Member
jithukuttamath
Message 1 of 4 (232 Views)
Problem with Creating Alignment
232 Views, 3 Replies
11-02-2012 11:21 PM
 I have a problem when i create an alignment with Select Object. The Chainage is not coming properly.
And here i attached the Print screen, please see that.
Distinguished Contributor
SurveyorLee
Message 2 of 4 (212 Views)
Re: Problem with Creating Alignment
11-03-2012 09:59 AM in reply to: jithukuttamath
The screen shot looks good.  If there are gaps left in the alignment, check to be sure the poly line is one entity.  I have had it leave gaps before when i had a section that was at a different elevation.  I don't do much work with the alignments, but since it's Saturday and you are working, I thought I would give it a go.
Surveyor Lee
Distinguished Mentor
castled071049
Message 3 of 4 (204 Views)
11-03-2012 11:09 AM in reply to: jithukuttamath
What, exactly, is the problem? It looks fine to me, without seeing the alignment properties.
neilyj
Message 4 of 4 (174 Views)
11-04-2012 09:39 AM in reply to: jithukuttamath
nothing obviously wrong with this; any more clues?
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
