Civil 3D Forum
Problem with corridor drive command
4 REPLIES 4
SigridJD
1512 Views, 4 Replies
I have created a corridor and would like to use the drive command. After choosing a featureline and then ETW, the response is "Selected path is not supported. Please select another path".
I have not had this problem with the drive command before.
Has anyone experienced the same and know a solution ?
Thanks in advance
Tags (2)
4 REPLIES 4
doni49
in reply to: SigridJD
Thanks in advance
I don't know for sure, but I *THINK* it needs an ALINGMENT (that has a profile associated) not a featureline.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
ceethreedee.com
in reply to: doni49
How strange. Got a similar problem with my file. Closing and opening the drawing fixed it. But still, wierd.
I think it happens if you zoom around when in drive mode.
Civil 3D 2021 (Update 1), ACAD (SP1.3) MAP (HF0.4)
Infraworks 2021.1,
Win 10 -DELL Precision Notebook 7730
ceethreedee.com
joalmo11
Hi colleages,
I am having the same problem.
I was not having problems at all with alignment 1 but when I added another one neither of them seem to work properly.
The same aforementioned error message is appearing.
I tried to close and open the file but it does not help in my case.
Any clues?
Thank you colleages
didntseeit
in reply to: joalmo11
I have the same problem. I am trying to drive along an alignment, then assigning a profile. I get the error message after attempting to select the profile.
Hope someone comes up with a solution soon. This project is due tomorrow!
Rail Community
