Hi Kevin,
Select the lane transition in your assembly and, in the properties window,
under the Advanced section, make sure the pulldown for transition is set to
"Change offset and elevation" or another appropriate choice based on your
situation.
Brian Hailey
LDT2005
C3D2005
XP Pro - SP 2
P4 2.8GHz
1.00 GB of RAM
"kevincurrey" wrote in message
news:3573941.1106897287300.JavaMail.jive@jiveforum2.autodesk.com...
> Can someone please help me understand what I'm doing wrong with a basic
> lane transition? Instead of conforming to my target alignment, the width
> stays at the default value. I have an assembly with a curb attached to
> the center and a basiclane transition attached to curb. Both are set to
> the left side. The lane has a default width of 12. The assembly is
> attached to my main alignment, with another alignment to the "left" that I
> target in the Logical Name Mapping Dialogue box. As I said, after I build
> the corridor, the lane doesn't adjust to the width, it just stays at 12.
> I'm fairly new to C3D so I'm willing to concede that I've missed
> something, but I have no idea what it could be. Thank you.
> Kevin Currey
