Hello, my name is Bruno and I'm Brazilian. From now on, I'm sorry for my bad English...
I have a problem: I'm trying to create a surface of a retention basin (is it correct this name?), but I am unable to make the walls.
I did a proposed model using 3dfaces, as follows:
Now by the Civil 3d like this (for the Object Viewer):
It seems that Civil 3D does not understand to make the triangulation on the Z axis.
I've tried the "trick" to fend 0.001 'coplanar lines but did not work
The file is this, if someone help me. I thank you.
There is not enough data from the perimeter contour ('PAREDE') to properly triangulate the TINN. Re-add it to your surface with a supplemental distance of 10m. That should add enough data to form the long walls.
