Civil 3D Forum
Welcome to Autodeskā€™s Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D topics.
Showing results forĀ
Did you mean:Ā
Problem wich Retention basin's surface
2 REPLIES 2
bruperton
264 Views, 2 Replies
Hello, my name is Bruno and I'm Brazilian. From now on, I'm sorry for my bad English...
I have a problem: I'm trying to create a surface of a retention basin (is it correct this name?), but I am unable to make the walls.
I did a proposed model using 3dfaces, as follows:
Now by the Civil 3d like this (for the Object Viewer):
It seems that Civil 3D does not understand to make the triangulation on the Z axis.
I've tried the "trick" to fend 0.001 'coplanar lines but did not work
The file is this, if someone help me. I thank you.
2 REPLIES 2
Karsten.Saenger
in reply to: bruperton
Hi Bruno,
looking at your sample data, I do not understand what you mean with "Civil 3D does not understand to make the triangulation on the Z axis". Could you please further explain what you expect from the triangulation?
Other than that, I am wondering if it does make more sense to build your basin with the grading tools of Civil 3D. Please see the tutorial files "Grading..." from the help folder for a quick impression how the results can look like.
Karsten.
Karsten Saenger
ccoles
There is not enough data from the perimeter contour ('PAREDE') to properly triangulate the TINN. Re-add it to your surface with a supplemental distance of 10m. That should add enough data to form the long walls.
Windows 7 64-bit
Dell Precision T5610, Dual-Xeon 2.6Ghz, 16 Gig RAM
Civil 3D 2013
Rail Community
Ā
Ā
