Civil 3D Forum
Problem Triming Contour lines...Any suggestion?
5 REPLIES 5
Linpat
593 Views, 5 Replies
Hi  all,
Up to now, I was able to trim contour (elevation) lines simply by drawing a polyline across the contour lines and use the trim command. But the function suddenly stop to work on my computer.
I have tried the function on other computers and it works very well.
Now, on my computer,  I can only trim one contour line after the other by adjusting the polyline to the same elevation as the contour line. This is rediculous if I have to trim hundreds of contour lines.
Because the problem is only on my computer, I suppose i have mistakenly apply a command that have change the settings on my computer.
I have reviewed my settings but cannot identify the problem.
Any suggestions?
5 REPLIES 5
KirkNoonan
in reply to: Linpat
Sounds like you need to change the 'Project' option to UCS. Check the command line after you execute the Trim command. You enter P for Project.
Pointdump
in reply to: KirkNoonan
Add a Boundary Definition to your surface.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
neilyj666
in reply to: Pointdump
I'd agree with this generally but it doesn't sound like the OP is working with a surface - just trimming polyline contours
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
wfberry
in reply to: Linpat
I think we need to know exactly what program and version you are using.  When you select these contour lines are they polylines?  If so, where did they originate?
Bill
Linpat
in reply to: Linpat
Thanks for your suggestions. I have resolved the problem by resetting my AutoCAD, following steps provided by the AutoCAD Civil 3D Services & Support!
Rail Community
