Problem running 2007
All the gurus out there may be able to help
I have loaded our stand alone civil3D 2007 & LDT Companion The insallation went without any hitches but when I try to run Civil3D I get the following errors and the can go no further and it will crash
Exception in C:\Program Files\Autodesk Civil 3D 2007\Civil\AeccUiNetwork40.arx ARX Command
Unhandled Exception E06D7363 (e06d7363h) at address 7C81EB33h
OK
Exception in C:\Program Files\Autodesk Civil 3D 2007\Civil\AeccUiRoadway40.arx ARX Command
Unhandled Exception C000001D (c000001dh) at address 4C25B60h
OK
LDT Companion will run ok
This is hapening on only one of our machines the other insallation worked ok on the windows 2000 machine.
I am running LDT/Civil design 2005, LDT/Civil Design 2006 and Civil 3D 2006 with no problems with the exception of a shutdown error aborting
Internal error: Atempt to access Aecbaseservice after shut down.
Have contacted our reseller and they are lost as to problem
3.0GZ extremm processor
2.0 gig ram
Radeon 9800 graphics
Windows XP sp2
Thanks for any help
