Civil 3D Forum
Problem Reimporting FBK
13 REPLIES 13
Message 1 of 14
jezzell
467 Views, 13 Replies
Lets start out by saying this did not happen in any other version of Civil 3d. We recently did a computer upgrade to our office. So when it came time to reload civil 3d, we chose to go with 2012 version. All was fine until I had to reimport an fbk.
I will typically start out by stripping the control loop out of the fbk file and balancing and making a text file of the loop (backup). Then I will bring in the rest of the location on to the balanced loop. If for some reason I need to reimport those locations for some reason it will remove any control points occupied in the last fbk file. Please let me know if something has changed or if the fbk file looks in correct.
Any help is appreciated
Windows 7 x 64 Professional
Clevo Laptop
Nvidia Quadro M3000
24 GB DDR3
256GB SSD
Quad core i7-6700k @ 4.0 GHz
Civil 3D 2015 SP3
Civil 3D 2017
13 REPLIES 13
Message 2 of 14
ToddRogers-WPM
in reply to: jezzell
Are you creating Networks?
Todd Rogers
Message 3 of 14
jezzell
in reply to: ToddRogers-WPM
yes I am creating network,
Clevo Laptop
Nvidia Quadro M3000
24 GB DDR3
256GB SSD
Civil 3D 2015 SP3
Civil 3D 2017
Message 4 of 14
ToddRogers-WPM
I am assuming you have all Updates and Hotfixes installed?
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9240698#section2
Todd Rogers
Message 5 of 14
jezzell
Yes We are currently up todate.
Clevo Laptop
Nvidia Quadro M3000
24 GB DDR3
256GB SSD
Civil 3D 2015 SP3
Civil 3D 2017
Message 6 of 14
jrauch
Any news on this?
-John J. Rauch, P.E.
Message 7 of 14
jezzell
No Still having the same problem. I have a work around, strip all control in to one fbk file and and all sideshots into another fbk file. I need to import the control file into one Survey Network (control) and then import any other fbk file into a different network (sideshots). Seems to be the only way to fix this.
Not a good remedy on large scale jobs that continue to grow.
Seems like a little to involved and should be easier.
Clevo Laptop
Nvidia Quadro M3000
24 GB DDR3
256GB SSD
Civil 3D 2015 SP3
Civil 3D 2017
Message 8 of 14
IanMcClain
I am have the same problem with 2012. You are correct: earlier versions did not do this. Re-importing is now very cumbersome. It has been broken and needs to be fixed by AutoDesk.
Ian McClain
Message 9 of 14
jezzell
in reply to: IanMcClain
The fix That I came uo with is to make a network for every import event, Yes still cumbersom but it does work.
I should be put back the way It was in previous versions!!
Clevo Laptop
Nvidia Quadro M3000
24 GB DDR3
256GB SSD
Civil 3D 2015 SP3
Civil 3D 2017
Message 10 of 14
_Hathaway
We stopped using FBK files as they seem like more of a hassle than they are worth. We merely import the CSV file. Sure, the FBK can get you all sort of fancy information but it's somewhat dysfunctional as you have pointed out.
Message 11 of 14
IanMcClain
Hallelujah! You just made my day.
So now I just need to make a network for importing adjusted control and a second network for fbks and then re-importing behaves like it used to.
Now if I can only remember to do that from now on with out blasting my control the first time and then remembering this post...still should be fixed by Autodesk.
Ian McClain
Message 12 of 14
IanMcClain
in reply to: _Hathaway
A big advantage of FBK is you can go survey without your final control and just use relative coordinates. Since FBK uses the observation data you don't have to wait or adjust your sideshots in another software to get them on the same datum. It's very usefull when you have large jobs and need to divide the work between multiple crews.
Ian McClain
Message 13 of 14
jezzell
Yes thats what I do! Now if only the field crew could remember the procedures
Clevo Laptop
Nvidia Quadro M3000
24 GB DDR3
256GB SSD
Civil 3D 2015 SP3
Civil 3D 2017
Message 14 of 14
_Hathaway
Yes, I'm aware of that scenario and we do still use FBK files for certain instances as you've described.
Rail Community
