Joe Bouza
This is happening to me as well when I try to publish multiple sheets to pdf. The program acts like it is working but the file doesn't exist. I'm using a cutepdf driver, I've reviewed the publish dialog settings and set 'publishallsheets' and publishcollate' system variables to (1) but the problem is not solved. As the previous contributor, I do get a message that quickly flashes across the screen so I can't read it. I'd like to try and correct the pc3 installation. Could I get some more direction on doing a reinstall for this? Thank-you.
