Civil 3D Forum
Problem Opening Saved Drawing
6 REPLIES 6
coralbliss
883 Views, 6 Replies
I saved and closed a drawing while in corridor section editor.  Now when I open it, it appears to be stuck in the section editor, and only displays some sketchy lines and a few dashes, nothing complete.  The section editor toolbar isn't open, so I can't click close section editor.
I've attached a screen shot.
How so I get back to my normal drawing?
Thanks!
Coral
6 REPLIES 6
wfberry
in reply to: coralbliss
Try This:
Set menubar to 1
Go to the Corridor dropdown menu and try that route.
Bill
Run into this all the time when I'm developing custom subassembies and forget to exist corridor section view when stopping debugger.
Open the file then enter "View" command, with Current selected as view, scroll down the properties on the right side of th dialog and turn the "Clipping" option to "Off". (See attached screen shot)
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
Jason.Hickey
The quickest way to get out of this custom view is to type "PLAN" at the command line (without quotes) and then hit Enter twice. That takes you to the world UCS view.
Jason Hickey
Premium Services Specialist
Autodesk, Inc.
Does PLAN reset the view clipping?
Mike Robertson
Thanks for the help, everyone, problem solved!
steve_davidson
The way I solve this is to simply select a corridor in the plan view widow and then click on the Section Editor., it's like your trying to open up Section Editor again.  This will bring up the normal Section Editor menu and on the RHS you can click the green close arrow to shut it down and get back in to the "normal" view.
Rail Community
