Civil 3D Forum
problem in adding point to surface
2 REPLIES 2
vijayant.nit
430 Views, 2 Replies
I have got a csv file and want to add to the surface but it says error in adding point file.....dont know what to do. Size of the csv is 13MB and contains about 0.2million points
2 REPLIES 2
rkmcswain
in reply to: vijayant.nit
Does the CSV file have any header lines in it?
I'm assuming this is a true comma separated ASCII file that can be opened in Notepad
As a test, carve out a few lines (±10) from the file and save as a separate CSV file, make sure there are no header lines and see if this will import.  Keep adding portions to this smaller file until it fails.
MikeEvansUK
in reply to: rkmcswain
Note: You can have headers but you must remember to add a # before them then use the invalid character feature in the import type and set it to match (#).
It is simpler not to as Rick suggests but sometimes you need them to jog your memory.
The point import can be ropey with some characters, I have gone as far as to open the txt file and remove all Spaces using find & replace to get the import to work. If a number has a space before it it will throw an error.
Also if you have opened edited and saved this in Excel as a CSV file (and maybe other types). Edit the file in notepad and save it again. I have found that sometimes excel messes with the formatting or file settings but notepad will fix this.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Rail Community
