Hello.
I'm having problems exporting COGO points from AutoCAD Civil 3D towards MX Road, using the GENIO tool provided by AutoDesk.
The COGO points created by the surveyor don't have a name set. (When looking at the name properties, name says: *Property not set*, even though the raw description is correct.) Thus, when trying to export it with the GENIO tool, I can't get it to rename each point group properly at the "string naming options" tab, since it always picks the "*" (no set name) option.
What can I do? Could anyone help me with this? Is there anyway to batch-rename all the COGO points from a given point group? Or to have the export tool look at the raw description, instead of the name?
Thank you in advance for your help.
