Hi Everybody,
I've been using Civil3D (2013) for a few months now and just yesterday something weird happened. I used to able to select an object, then enter a command and it would apply to whatever objects I selected. For example, I could select a line, then type M, and the move command started for that line. Now when I select a line and type M it deselects that line and asks me to select the objects I want to move, as if nothing was selected when I started the move command. What weird button did I press or box did I check to make this happen?
Thanks all,
-Dan K.
Solved by mathewkol. Go to Solution.
