Civil 3D Forum
problem creating Infill grading - filling Holes
17 REPLIES 17
Message 1 of 18
bernd.rosemann
11874 Views, 17 Replies
creating infill at the grading example from the civil 3d tutorial "filling holes in a grading" (grading-6.dwg) failes when selecting the area to fill. The command finshes whithout changing the model. There is no diamond symbol displayed.
any ideas what is going wrong? why i am not able to select the area?
17 REPLIES 17
Message 2 of 18
Joe-Bouza
in reply to: bernd.rosemann
First I would audit , purge a purge reg apps and try again.
Secondly, I would look for an openinf in the feature lines. The infill only works with closed series of feature lines
Your Name
Message 3 of 18
bernd.rosemann
in reply to: Joe-Bouza
what do you mean with "purge reg apps"?
There are no gaps at the feature lines, because there is a solution file which includes the infill. But after deleting and trying to redefine the infill I had the described trouble. Attached you will find the tutorial file. Are you able to have a look at this and describe me the solution in more detail?
Message 4 of 18
Joe-Bouza
Unfortunately I do not have cad at my disposal right now. If I recall the tutorial correctly it is the building foot print with the ramp between a lower section. Are you trying to create the infill between the building feature line anf the offset feature line and did the offset feature line go into the same site as the grading? if no there is your answer. FL have to be in the same site for infill to work.
Did AUDIT show any errors?
Run Audit until no errors show up
Use the cammand line purge:
-pu A * <enter> N.
-pu R * <enter> N
Your Name
Message 5 of 18
bernd.rosemann
thank you so far ... but I have no idea whats going wrong, maybe it is a simple stupig thing? I used the finished exercise drawing and deleted the infill, so I should have a good starting point to resolve. Doing the modifications again, I have the same problem - nothing happens. Please have a look.Bild1.jpg
Message 6 of 18
ich hab's gerade mit 2013 probiert (Deinen Screenshots zu folgen) und das hat funktioniert. Welche Civil3D-Version hast Du?
I just tried it with 2013 and it worked (following the screenshots), what version of Civil3D do you have?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 7 of 18
Civil 3D 2013 product version G.55.0.1, HF2.1
Message 8 of 18
Joe-Bouza
are you deleting the infill with an autocad delete command or with the c3d delete grading command?
Your Name
Message 9 of 18
bernd.rosemann
deleting by selecting via mouse and hitting the del-key
Message 10 of 18
Joe-Bouza
keinen Sinn, sinnlos, keinen Zweck, zwecklos, hilft nicht
I hope the on line translator did punk me, That is NO Good.
ALWAYS use the grading ribbon or right click to delete gradings. It is not a gaurentee but the way you are doing it can lead to trouble (and may have).
Your Name
Message 11 of 18
I did it the same way, and for me it is working (based on your uploaded 7-drawing.
- alfred -
Alfred NESWADBA
Message 12 of 18
thats good, but unfortunately that is not helpful for me. It seems I make a simple maybe stupid beginner error? Any ideas?
Message 13 of 18
Joe-Bouza
We could make a better guess if you could post the drawing file
Your Name
Message 14 of 18
bernd.rosemann
plaese see message 3 from (10-13-2012 04:07 PM)
Message 15 of 18
look to the attached video, maybe you can find differences in the way we are doing/clicking/typing.
- alfred -
Alfred NESWADBA
Message 16 of 18
Thanks a lot - this was very helpful.
It seems that it works only, when the selection of the infill areas are done in a top view (right side of the window)?
BR
Message 17 of 18
Hello, I know it's an old post, but I had this problem several times, when I needed to make changes to the Feature Line vertex geometry, I ended up needing to delete Infill and then it was not created again when I needed it, I used the command Audit and it worked like magic, I was able to recreate all the Gradings I needed, now whenever this error occurs, I use Audit and the whole drawing works again.
I discovered this function in this post, so I'm leaving the feedback to help those who have the same problem.
Message 18 of 18
What work for me,
  • Draw Polyline again.
  • Convert object to Feature line.
  • Create Grad infill.
  • Create surface from infill(in the "Create ground Data_Surface" TAb) .
Leave a like if this work!!!
Rail Community
