bernd.rosemann
Message 1 of 16 (1,923 Views)
problem creating Infill grading - filling Holes
1923 Views, 15 Replies
10-12-2012 04:27 AM
creating infill at the grading example from the civil 3d tutorial "filling holes in a grading" (grading-6.dwg) failes when selecting the area to fill. The command finshes whithout changing the model. There is no diamond symbol displayed.
any ideas what is going wrong? why i am not able to select the area?
Thanks a lot - this was very helpful.
It seems that it works only, when the selection of the infill areas are done in a top view (right side of the window)?
BR
Joe-Bouza
Message 2 of 16 (1,900 Views)
Re: problem creating Infill grading - filling Holes
10-12-2012 03:21 PM in reply to: bernd.rosemann
First I would audit , purge a purge reg apps and try again.
Secondly, I would look for an openinf in the feature lines. The infill only works with closed series of feature lines
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
bernd.rosemann
Message 3 of 16 (1,888 Views)
10-13-2012 07:07 AM in reply to: Joe-Bouza
what do you mean with "purge reg apps"?
There are no gaps at the feature lines, because there is a solution file which includes the infill. But after deleting and trying to redefine the infill I had the described trouble. Attached you will find the tutorial file. Are you able to have a look at this and describe me the solution in more detail?
Joe-Bouza
Message 4 of 16 (1,883 Views)
10-13-2012 08:22 AM in reply to: bernd.rosemann
Unfortunately I do not have cad at my disposal right now. If I recall the tutorial correctly it is the building foot print with the ramp between a lower section. Are you trying to create the infill between the building feature line anf the offset feature line and did the offset feature line go into the same site as the grading? if no there is your answer. FL have to be in the same site for infill to work.
Did AUDIT show any errors?
Run Audit until no errors show up
Use the cammand line purge:
-pu A * <enter> N.
-pu R * <enter> N
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
bernd.rosemann
Message 5 of 16 (1,875 Views)
10-13-2012 12:06 PM in reply to: Joe-Bouza
thank you so far ... but I have no idea whats going wrong, maybe it is a simple stupig thing? I used the finished exercise drawing and deleted the infill, so I should have a good starting point to resolve. Doing the modifications again, I have the same problem - nothing happens. Please have a look.Bild1.jpg
Alfred.NESWADBA
Message 6 of 16 (1,872 Views)
10-13-2012 12:27 PM in reply to: bernd.rosemann
ich hab's gerade mit 2013 probiert (Deinen Screenshots zu folgen) und das hat funktioniert. Welche Civil3D-Version hast Du?
I just tried it with 2013 and it worked (following the screenshots), what version of Civil3D do you have?
- alfred -
Alfred NESWADBA
bernd.rosemann
Message 7 of 16 (1,868 Views)
10-13-2012 12:56 PM in reply to: Alfred.NESWADBA
Civil 3D 2013 product version G.55.0.1, HF2.1
Joe-Bouza
Message 8 of 16 (1,861 Views)
10-13-2012 01:45 PM in reply to: bernd.rosemann
are you deleting the infill with an autocad delete command or with the c3d delete grading command?
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
bernd.rosemann
Message 9 of 16 (1,858 Views)
10-13-2012 01:59 PM in reply to: Joe-Bouza
deleting by selecting via mouse and hitting the del-key
Joe-Bouza
Message 10 of 16 (1,852 Views)
10-13-2012 02:30 PM in reply to: bernd.rosemann
keinen Sinn, sinnlos, keinen Zweck, zwecklos, hilft nicht
I hope the on line translator did punk me, That is NO Good.
ALWAYS use the grading ribbon or right click to delete gradings. It is not a gaurentee but the way you are doing it can lead to trouble (and may have).
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
