Inserted an alignment line table. It's in model space and viewported (locked) to the layout. On the screen it looks fine but during print preview and printing it comes out too small. Can this be controlled?
Not sure I'm completely following but do PSLTSCALE=1, MSLTSCALE and LTSCALE=1 in the drawing?
I set those to match. Did what Jay described as well. Better but still too small. Can it be scaled up?
This could probably be solved rather quickly if you either posted it or sent it to someone. (Can you knock it down to something if you are concerned about possible liability?)
Bill
BTW, what version are you using. We normally like OS, etc.
Couple more things to check.
Is ANNOALLVISIBLE <0>: 1?
Is viewport type: Plan?
Tried all these settings. Still get a small table in print preview. See attached
Gentlemen. Sorry for all this. I have not used tables before. It was all in the styles settings. Got it now.
Thanks for the effort
