hi i have problem in civil 3D 2013 when i try to print with window mode , when i am try zoom in with mouse scrol printig function is disapiaring and after i must klick escape several times for re use print eny one can tell me what is problem meby bug or something
thx.
p.s. sory for my bad english
Solved by wedzisi. Go to Solution.
I can confirm that, but as I normally print using layouts and so not using "Window" to define the plot-area it's not something really hurting (for me).
- alfred -
So a workaround would be to draw lines from or center circles at the point you need to pick for your window. Make them big enough so you can select them without zooming in and put them on a no-plot layer.
Or just plot from a layout.
Allen
Allen Jessup
CAD Manager - Designer
yeah you are right also i am ploting from lay out but somtimes i am geting lage drowings for ex. 13km road plan its tender document and the i need just som section i am ploting with window thes is not so big problem but somtimes i am forgeting and geting nervos 😄 so if autodesk will fix it will be beter
It says at the top of the forum this has been solved. Is there a hotfix for this one yet?
Yes I can get around it but still annoying..like docking a command line to get around glitches.
After hours of research I have yet to find a solution which fixes this problem. From what I have been told this issue has been resolved in Civil 3D 2014. Can someone from Autodesk please chime in on this subject regarding a upcoming HotFix or soltion to fix this problem.
Mike
I'm not from Autodesk, but if I'm allowed to try it: I can't reproduce this issue with C3D2014 (German, Win7x64)
- alfred -
One work around that works "sometimes" to get out of the loop is to right click and hit enter and it will give you back your pick appature. It's not 100% but I have found it better than hitting escape 1000 times before starting the plot process over again LOL
