Active Contributor
wedzisi
Message 1 of 10 (965 Views)
Printing problems with window mode in Civil 3D 2013
965 Views, 9 Replies
10-11-2012 10:32 PM
hi i have problem in civil 3D 2013 when i try to print with window mode , when i am try zoom in with mouse scrol printig function is disapiaring and after i must klick escape  several times for re use print eny one can tell me what is problem meby bug or  something
thx.
p.s. sory for my bad english
Alfred.NESWADBA
Message 2 of 10 (951 Views)
Re: Printing problems with window mode in Civil 3D 2013
10-11-2012 11:52 PM in reply to: wedzisi
I can confirm that, but as I normally print using layouts and so not using "Window" to define the plot-area it's not something really hurting (for me).
- alfred -
Alfred NESWADBA
rkmcswain
Message 3 of 10 (935 Views)
10-12-2012 07:46 AM in reply to: wedzisi
Agreed. Known bug.
AllenJessup
Message 4 of 10 (924 Views)
10-12-2012 08:18 AM in reply to: wedzisi
So a workaround would be to draw lines from or center circles at the point you need to pick for your window. Make them big enough so you can select them without zooming in and put them on a no-plot layer.
Or just plot from a layout.:smileyhappy:
Allen
Active Contributor
wedzisi
Message 5 of 10 (897 Views)
10-13-2012 03:02 AM in reply to: AllenJessup
yeah you are right also i am ploting from lay out but somtimes i am geting lage drowings for ex. 13km road plan its tender document and the i need just som section i am ploting with window  thes is not so big problem but  somtimes i am forgeting and geting nervos :smileyvery-happy: so if autodesk will fix it will be beter
New Member
civil
Message 6 of 10 (807 Views)
11-05-2012 04:30 PM in reply to: wedzisi
It says at the top of the forum this has been solved. Is there a hotfix for this one yet?
Yes I can get around it but still annoying..like docking a command line to get around glitches.
rkmcswain
Message 7 of 10 (760 Views)
11-14-2012 08:13 AM in reply to: wedzisi
New Member
mikeg
Message 8 of 10 (525 Views)
04-11-2013 09:01 AM in reply to: wedzisi
After hours of research I have yet to find a solution which fixes this problem. From what I have been told this issue has been resolved in Civil 3D 2014. Can someone from Autodesk please chime in on this subject regarding a upcoming HotFix or soltion to fix this problem.
Mike
Alfred.NESWADBA
Message 9 of 10 (521 Views)
04-11-2013 09:08 AM in reply to: mikeg
I'm not from Autodesk, but if I'm allowed to try it: I can't reproduce this issue with C3D2014 (German, Win7x64)
- alfred -
Alfred NESWADBA
Valued Contributor
tddbuck
Message 10 of 10 (515 Views)
04-11-2013 09:24 AM in reply to: Alfred.NESWADBA
One work around that works "sometimes" to get out of the loop is to right click and hit enter and it will give you back your pick appature.  It's not 100% but I have found it better than hitting escape 1000 times before starting the plot process over again LOL
