George-Handley
Message 1 of 10 (1,029 Views)
Printing a pdf from a large civil3d file, to large to handle
1029 Views, 9 Replies
04-03-2013 05:16 AM
Hey guys,
I am having trouble working with a large civil3d file.
My issue is that when I print a pdf file from my dwg file (which is apprix 140mb large), the pdf file that comes out is more than 30mbs.  My work laptop can't handle a pdf file this size, let alone print it or email it.
I am after some advice on working with large civil3d files (it is the surface model of some scan data which is slowing it down).  I can accept that the civil3d file is large and difficult to do work with quickly, but not being able to print out a pdf file which i can easily send to my client is very annoying.
Please select the following link (https://dl.dropbox.com/u/9908922/Large%20autocad%20files.zip) to download my dwg file and pdf files.  Warning that the total file size is approx 300mbs.
So just to repeat, I am chasing advice on:
 - working with a large dwg file, I am dealing with surface models generated from scan data.
 - how to print a small pdf file from my dwg file.
Any and all help will be greatly appreciated.
George
George, Hope this helps. I've run into this same issue and haven't attempted to do what Todd suggested so that may be a better "fix". What I like to do is once the large PDF has been created, export it from Adobe Acrobat as a high resolution JPG. This gets rid of all the massive data that autocad creates when printing elevation banding. Then using Acrobat again convert the JPG to a PDF and the file size is quite minimal. See attached. I used a JPG medium quality setting and ended up with a 400KB document instead of the 30MB.
dasindog
Message 2 of 10 (1,022 Views)
Re: Printing a pdf from a large civil3d file, to large to handle
04-03-2013 05:26 AM in reply to: George-Handley
George, I'm downloading now. Will let you know if I have any suggestions.
-Dustin
Civil 3D 2013 64 bit SP1
Windows 7 Pro 64
Intel Xeon 2.93GHz
24GB RAM
NVIDIA Quadro FX 580
explodetheblock.wordpress.com
George-Handley
Message 3 of 10 (1,017 Views)
04-03-2013 05:36 AM in reply to: dasindog
Wow very prompt Dustin!  Like I said any and all advice would be greatly appreciated.
TRogers
Message 4 of 10 (1,000 Views)
04-03-2013 06:04 AM in reply to: George-Handley
Try these settings...
http://totalcad.wordpress.com/2010/04/07/fix-for-out-of-memory-errors-due-to-large-image-files/
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
dasindog
Message 5 of 10 (982 Views)
04-03-2013 07:01 AM in reply to: dasindog
-Dustin
Windows 7 Pro 64
Intel Xeon 2.93GHz
24GB RAM
antoniovinci
Message 6 of 10 (957 Views)
04-03-2013 11:23 AM in reply to: dasindog
I think rasterizing a vector map (specially in a lossy format as JPEG) is definetely never a good idea, sir.
You should try to set a lower resolution in your PDF virtual printer, increasing it gradually up to the desired compromise.
George-Handley
Message 7 of 10 (919 Views)
04-05-2013 06:25 PM in reply to: dasindog
Thanks for that Dustin.  That's what I was looking for.  I was trying to compress the pdf file but it kept crashing my computer, didn't even think about exporting it.
George-Handley
Message 8 of 10 (915 Views)
04-05-2013 06:28 PM in reply to: TRogers
Thanks for the link Todd.  When I get more time i'm going to go through those settings and see if it helps me.  I'm always cautious about getting too deep in civil3d settings, i don't want to break it!
Joe-Bouza
Message 9 of 10 (911 Views)
04-05-2013 07:27 PM in reply to: George-Handley
In addition to the other advice For the heck of it, 300MB dwg  sounds like there may be some header issues; try Audit purge all purge regapp, wblocking the file contents out and see if comes down some
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
George-Handley
Message 10 of 10 (896 Views)
04-05-2013 08:23 PM in reply to: Joe-Bouza
Thanks for that Joseph.  I did try that initially on the lowest DPI setting but it didn't change it to significantly for me.  I might try it again just to check i was doing it correctly.
