I am having trouble with the plot styles and getting my printer to plot according to the selected plot style. I have modified the acad.ctb plot style so that all of the colors are set to black. However, despite this, when I do a 'plot preview' the colors still show up. And when I do an actual plot, it is in color as well.
I have messed around with the printer settings in 'control panel' and tried changing the default printer setting to greyscale but then the printer just plots the drawing according to the greyscale equivalent of the colors in AutoCAD.
So, what setting am I forgetting to change? In the options menu, under the plotting tab, I have made sure that the plot style was set to acad.ctb. I have reassigned all of the colors to black in acad.ctb. I have turned greyscale to "on" along with dither for all colors in acad.ctb. And the sheets still come out in color. What's going on?
Note: I have left my printer settings (in control panel) on Auto Color. I have done this so that I can tell when things are working properly, since it seems to me that if all of my colors are set to plot black, they should plot black even though the printer is set to Auto Color. Is this sensible?
Thanks in advance guys
Thanks for posting the answer.
Allen Jessup
Allen Jessup
CAD Manager - Designer
I am experiencing the same difficulties. I have checked the plot style in properties panel - but still no luck
Using AutoCAD (Not C3D), I solved this problem by changing the visual style back to 2D Wireframe. Other styles seem to override the .ctb
