Works fine in 2012..... just checking 2011......yep thats fine too
neilyj (No connection with Autodesk other than using the products in the real world)
... when I typed in layerhtm2 I got nothing ...
I believe the command would remain LayerHTM (case doesn't matter but no number 2).
i typed layerthm also but got nothing
not sure what i did wrong
you can put it in any folder right just so you go to that fiel when you first do netload right
You can put the DLL in any folder. Once it's loaded with NETLOAD one time, it registers itself for autoloading. The command is LayerHTM.
There is a comparable version in the PlugIns of the Month which includes source code.
It's a heavily used item and nobody has complained of it not working before (except LT users).
In AutoCAD's Layer Manager, do a Ctrl+A then Ctrl+C and paste into Excel?
Thanks so much for your help
I don't know why the netload didn't work
IM sure something perhaps operator error ha ha
but the
did work thanks so much
appreciate your site
dj
I was looking around and it said it didn't work with 64 bit
FYI
have a great weekend
dj
