Civil 3D Forum
Preventing Linking Along the Same Survey Line
4 REPLIES 4
225 Views, 4 Replies
linking issue.jpgsee how linking is happening between points along the same survey line?
any ideas how to prevent this?
4 REPLIES 4
tcorey
Run some breaklines from one survey line to the other across the area where the TIN is interpolating incorrectly.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
thanks, i tried the command "breakline" and connected 2 points across the 2 survey lines and all it did was draw a line with a "Z" in it and didn't seem to change the surface linking, sorry for my cluelessness but what is the correct command/procedure here?
nevermind, thanks ... ran through breakline tutorial and got it to work
mathewkol
FYI wings, this scenario will repeat itself over and over foy you in the future. The algorythm used to generate TIN surfaces (which nearly all software uses I think) is great, but it's correct maybe 80 or 90% of the time depending on the nature of elevation point layout.
The more breaklines that are picked up in the field, the less TIN editing you need to do.
The sample you gave us this time, a breakline would probably not be something a surveyor would pick up. Sometimes you just don't know how the TIN will be generated. No, this is just one of those thing you need to spot with dilligent surface editing skills. Which you obviously picked up...good.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Rail Community
