Civil 3D Forum
Pressure Pipes Compass
5 REPLIES 5
ToddRogers-WPM
952 Views, 5 Replies
I have tried a thousand different scenarios with the new pressure pipes.  When I create a new parts list and try to draw a water line, the compass only gives me 3 angles.  This is using the "out of the box" templates.  How do you fix this?  Anyone?  Autodesk?
Todd Rogers
5 REPLIES 5
Jeff_M
in reply to: ToddRogers-WPM
Make sure to add elbows for the change in direction. The Compass is showing allowable deflection. I didn't get it to change until I added 2 with different angles.
ToddRogers-WPM
in reply to: Jeff_M
I have all sizes and bends in my parts list and it still doesn't work...
Todd Rogers
Jeff_M
I notice the pipe is PVC, but the bends are Ductile Iron. I'm guessing you can't mix materials.
ToddRogers-WPM
in reply to: Jeff_M
All I did was rename it in the catalog editor...maybe that is it, not sure.  i will try it out and let you know.
Todd Rogers
ToddRogers-WPM
in reply to: Jeff_M
That was it.  Thanks Jeff.
Todd Rogers
Rail Community
