New Member
0 Kudos
Post 1 of 3
Pressure Pipe Network
220 Views, 2 Replies
01-16-2013 12:21 AM
I have created a pressure pipe network (Plan view) from own created pipes and fittings, try to create an alignment from the network but C3D tells me that the selected network part has no connected parts?
How would I connect the network in order to create an alignment? (the pipe network has got a command to do that)
169 Kudos
Post 2 of 3
Re: Pressure Pipe Network
01-16-2013 05:33 AM in reply to: Hannah-Marie
When creating an alignment from a pressure pipe, you must select the first pipe, then the last pipe on the pipe run.
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
New Member
0 Kudos
Post 3 of 3
01-16-2013 05:41 AM in reply to: TRogers
Thanks, but that would not work because when I select my first pipe, pop-up comes up telling me that it has no connections, tried the next and next with same answer.  So what I did was delete the first pipe and redraw it making sure that it connects to my fitting, and then only it works.  I thought I had to redo my whole network but lucky for me, that was not necessary.
Thanks anyway!
