We just upgraded to 2013 and supposedly I should click the home tab -> pipe network -> pressure pipe network. But it isn't there. I can see that option in my toolspace and prospector, just nothing in my ribbons. Not sure what I am missing, but any help would be much appreciated.
Solved by Alfred.NESWADBA. Go to Solution.
is it possible that you are using the menu (CUIX) from Civil3D 2012?
- alfred -
It is possible. That is what I was originally thiking. I reloaded the c3d.cuix and nothing else came up. Is there any other files that may have gotten replaced.
Just to make sure:
from what directory? ... should be loaded from a 2013-directory
with what command? ...should be loaded with command _MENU
- alfred -
I was doing it through manage and import, but using _menu fixed it. Not sure what the difference is, but thanks so much for that tip.
The difference is that
Your try with import: you added a new menu to the existing ones (an additional partial menu), but your main-menu was the same as before and so you saw no change.
_MENU unloads the previous menus (main menu and partial ones) and makes the new one to your main-menu.
- alfred -
pressure pipe networks have their own nodes in the menus; they are not under pipe networks, they are under pressure pipe networks. And so on.
Steve Rogers
Cad Designer
Waterworks Engineers
Scottsdale, Az
